i have an Ls/vtec motor b18block/b16 head going into a 97 Civic hatchback which header will fit that chassy a b16 header or a b18 header i herd that one is longer then the other and one is too short and hits the oil pan please help Thanks
sorry for bumping a 2 month old thread, but your question was never answered, you will need the header for the B18, the deck height on the 1.8 is taller than the B16 using a b16 header will cause the header to basically be touching the oil pan if you can get it to fit at all.
