I have just fully disassembled a 1998 Dodge Ram 1500 and have all of the following parts. All prices listed are negotiable. Parts can be picked up or I can also ship if needed but buyer pays shipping. All parts were pulled out the truck in working condition but I have no way of testing them. I am an honest guy and can work with you if you receive something that does not work. Email me for more information or to set up a time to view/buy parts.
kennylarowe@nycap.rr.com
Thanks for looking.
Rear doors : $100 with window; $60 without : Both rear doors are black. One of the doors has the window installed and the other has had the window taken out. The door with the window has some rust on the lower section but is in fairly good condition. All parts of the window are in good condition. The door without the window includes the window but I am not sure how the windows mount and whether or not the mounting plates/hardware are there. There is a some scratching/denting on the lower section but it appears to be easily fixable. Both doors include the interior door panel and all handles/latches. I will try to get pictures up shortly. Pick-up only (no shipping).
Rear Sliding Window: $100 : The glass is in near perfect condition. There is one little mark on the left side but it doesn’t appear to be a scratch so it will most likely clean right off with a little careful elbow grease. It is missing the latch, which can be found online (rockauto.com) for very cheap. I will try to get pictures up shortly. Pick-up only (no shipping).
Steering column/linkage: $50 : The steering column includes all linkage up to the steering box. None of the electronics are on the column with the exception of the airbag. The airbag is 100% in-tact with no damage. Steering wheel has all buttons for factory cruise control. The horn was rewired to a button so I am not 100% if the horn is working or if the previous owner just wanted something different. It is currently fully assembled however I can disassemble for shipping if needed. I will try to get pictures up shortly.
Main engine computer: $120 : Some minor oxidation on the outside casing. All connector pins are 100% corrosion free and completely straight. Casing can be easily polished to remove oxidation if you really wanted.
Airbag module/computer: $75 : Outer casing is a little dirty, but all pins are 100% corrosion free and straight. Airbags were never deployed and airbag light was never on so there should be no issues with the module.
Passenger airbag on/off switch: $25 : One of the tabs is broken off, and there is a small piece of plasting broken along the bottom (see picture) but nothing can be seen when it is installed. The top 2 tabs were holding it in perfectly fine before I removed it. Harness is 100% in-tact.
Passenger Airbag with plastic surround: $75 : Airbag has never been deployed and is 100% in-tact. The plastic surround has a 3" crack along the break line for the airbag (see picture). Barely noticeable once installed and can probably be fixed fairly easily.
Passenger Airbag trim panel: $15 : Small 2"wide x about 15" long trim panel that goes along the bottom of the pass. airbag (hides the bolts). In perfect condition.
A/C Compressor: $75 : I never had the truck running, but the A/C system was 100% pressurized so I would have to assume that the compress is working properly. Once again, I cannot test anything but will work with you the best I can if it does not work. I will try to get a picture up shortly.
A/C Condenser: $50 : I never had the truck running, but the A/C system was 100% pressurized so there are obviously no leaks. There are a few dented fins here and there from normal use. A/C hardline (to accumulator) is still in-tact. Rubber line has been cut. I will try to get a picture up shortly.
A/C Accumulator: $20 : I never had the truck running, but the A/C system was 100% pressurized so the accumulator does not have any leaks. The hardline connector has been bent up due to difficulties removing (see picture) but should be able to be bent back into place. The spring is missing for that connector.
Throttle cable : $10 : The cable moves 100% freely with no visible kinks. Both connectors are in good condition.
Column Shifter Surround : $20 : No cracks, and the clips still hold tight. Rubber piece that follows the shifter is still 100% in-tact.
Rear View Mirror: $30 : With auto-dimming control. Has mounting bracket, but not the piece that glues to the windshield. No cracks or heavy scratches in glass. Normal wear and tear.
Auto-retract rear seatbelts: $20 : Auto-retract works perfectly. Normal wear and tear with no rips or tears in the belts. Includes buckles in same condition (not pictured).
Rear under-seat panels: $20 : These panels cover the brackets that hold the rear bench seat. No cracks or other damage. Great condition.
Rear verticle panels: $20 : Great condition. No missing clips however 1/2 of one clip is separated from the panel (can easily be glued back on). Clips are not bent or damaged. Panels are a little dirty with normal wear and tear.
Rear Harness (lights, trailer, etc): $20 : Some wires have been cut. Trailer plug was removed but wires are still pinned. Main front connectors and all tail-light connectors are in-tact.
Rear seat cupholder: $10 : Mounts underneath center console and slids out for 2 rear cupholders. Cover place is missing but the cupholder is not broken (tabs on cover broke off; no damage to actual cupholder). “Ratchet” for adjustable sizes still works 100%. Includes metal mounting bracket.
Complete Pedal assembly : $30 : Includes gas pedal and brake pedal. Brake pedal rubber is missing. Also includes brake switch.
Passenger Door harness: $25 : All wiring in good shape. 1 connector is damaged from disassembly (see picture). If buyer can supply a new connector with at least 4” of pigtail, I will solder the new connector for free!
Parking Brake Assembly: $25 : Brake assembly works perfectly. Outer rubber covering of cable was damaged during disassembly (see picture) but it did not affect the cable at all.
Overhead Rear door latch trim panels: $20 : These panels cover the top latches for the rear door. Tan in color. No cracks or damage (just a little dirty).
Overhead wire harness: $20 : This harness goes up the driver A-pillar and connects to the visors, mirror, and center overhead computer. Wiring and all connectors in good shape.
Overhead trip/information computer: $50 : In good condition. Wiring appears to be undamaged so it should work without issue. Light switches appear to work perfectly.
Multi-function switch: $30 : This switch mounts to the side of the column and controls the blinkers, wipers, high-beams, etc. In good condition. All pins are straight and corrosion free.
Seatbelt Module: $50 : This module controls the auto-lock on the seatbelts. All connectors and wiring is in good condition.
Main interior harness: $25 : This harness follows down the driver side and connects to most of the interior electronics including both rear doors. All wiring and connectors are in good condition.
Knee bolster Support Brace: $20 : Mounts behind the plastic knee bolster and acts as the main support for the lower dash.
Kick Panels: $20 : Both sides in good condition. No cracks/damage, just a little dirty
Hood release: $20 : Includes release handle, cable, and latch. The small plastic clip on the latch side of the cable is ½ broken (half circle instead of full circle; see picture). It still clips and locks into the latch, but may need something to help hold it in place. Latch and handle both in good condition.
Complete Heater Assembly: $50 : Includes full casing, heater core, and all actuators. Everything is in good visual condition. All actuators move freely. Both hard-lines are in good condition. Pick-up only (no shipping).
Knob style Headlight switch: $20 : All terminals are straight and free of corrosion. Knob moves freely. Good visual condition.
Main engine fuse box w/ full harness: $50 : All wiring in good condition. Fuse box in good condition. Ground wires will need new ring terminals but everything else is 100%.
Dome Light: $10 : Tan in color. Plastic is in good condition. No cracks or any other damage.
Steering Column Trim: $20 : All plastic in good condition. All clips hold tight.
Coin Tray Support: $20 : Metal support piece inside the coin tray. In good condition.
Instrument Cluster: $50 : All plastic in good condition. The back of the cluster is clean and free of corrosion. Unknown mileage. The shift indicator cable is broken where it locks into the cluster (see picture). Can easily be replaced or possibly repaired.
3rd Brake light: $20 : Factory 3rd brake light in good condition. Connector and wiring is 100% in-tact. Has cargo lights.
Passenger Headlight: $20 : Plastic is a little faded but over-all in good condition. I will try to get a picture up shortly.
Radiator Support (Upper): $30 : This is the support cross-brace that holds the top of the radiator. I will try to get a picture up shortly. Pick-up only (no shipping).
Radiator Support (Lower): $50 : this is the main front support brace that is shaped like a “U”. It holds the radiator from underneath. I will try to get a picture up shortly. Pick-up only (no shipping).
Battery temp sensor: $20 : This is the little sensor that mounts to the bottom of the battery box. Wiring and connector are in good shape.
Complete Wiper assembly: $50 : Includes wiper motor, arms, etc. Everything is in good visual condition. I will try to get a picture up shortly.
