well since i seem to be the ebc nazi i will start a thread based specifically on electronic pulse width modulation solenoids
since i know and specifically work on fwd honda’s i will give my input
this thread is not about greddy profec b’s, or apexi avcr, it has to do with pwm controlled solenoids
for honda currently hondata, ectune, aem ems and neptune can control this , as well as most stand alones, if your tuning software does not support pwm control then im sorry this does not apply to you
benefits:
can control boost via duty cycle for rpm/gear
- this allows the user to ramp up the boost, have lower boosts in lower gears to get maximum traction, yet still have the high horsepower in 3/4 gears
- by using this with an external wastegate it allows quicker spool time by keeping the gate shut completely untill desired boost level is reached
- allows fine tuning of the hp/tq curve by fine tuning the boost
- allows you to set a target pressure and the ecu keeps the boost at a steady pressure (lets the ecu do the work and makes for overall more consistent power)
- when set up as normally closed, if a failure of the solenoid occurs the only thing that will happen is that you run wg spring pressure
how all this benefits you over a manual boost controller with a fwd or high horsepower car with the proper ems
it allows the car to have 2 “maps” with the flick of a switch you can run a “street” tune with lower boost in first and second gears to try and maintain maximum traction on street tires and yet still have that high power for 3rd and 4th gears, the second map can have higher boosts in the gears again for maximum traction with given tires
for any honda who is putting down over 350whp this is a great feature to be able to do from a laptop on your own car, it enable fine tuning of the power band to maintain traction to have that edge over the car you are lining up with
cons- takes some more time to set up
if you are getting traction in first or second gear than this is obviously not for you, but at some point you will have too much power to maintain traction in the lower gears and that is where an ebc via pwm will give you the edge over the competition
AGAIN THIS IS NOT FOR CARS GETTING BELOW 2.0 SIXTY FEET ON STREET TIRES LOL, im sure it could definetly help though with some fine tuning , and most certainly help with boost fluctuation problems
thanks, and good info that will be easy for people to find :tup: carry on
