Saw this on some other forum forget which one. Didnt see it posted here, (knock on wood)
WOMEN:
- Pull up to Jiffy Lube when the mileage reaches 3000 since the last oil change.
- Drink a cup of coffee.
- 15 minutes later, write a check and leave with a properly maintained vehicle.
Money Spent:
$20.00 Oil Change
$1.00 Coffee
$21.00 Total
MEN:
- Go to auto parts store and write a check for $50 dollars for oil, filter, kitty litter, hand cleaner and scented tree.
- Discover that the used oil container is full. Instead of taking it back to recycle, dump in hole in back yard.
- Open a beer and drink it.
- Jack car up. Spend 30 minutes looking for jack stands.
- Find jack stands under kid’s pedal car.
- In frustration, open another beer and drink it.
- Place drain pan under engine.
- Look for 9/16 box end wrench.
- Give up and use crescent wrench.
- Unscrew drain plug.
- Drop drain plug in pan of hot oil; get hot oil on you in process.
- Clean up.
- Have another beer while oil is draining.
- Look for oil filter wrench.
- Give up; poke oil filter with screwdriver and twist it off.
- Beer.
- Buddy shows up; finish case with him. Finish oil change tomorrow.
- Next day, drag pan full of old oil out from underneath car.
- Throw kitty litter on oil spilled during step 18.
- Beer. No, drank it all yesterday.
- Walk to 7-11; buy beer.
- Install new oil filter making sure to apply thin coat of clean oil to gasket first.
- Dump first quart of fresh oil into engine.
- Remember drain plug from step 11.
- Hurry to find drain plug in drain pan.
- Hurry to replace drain plug before the whole quart of fresh oil drains onto floor.
- Slip with wrench and bang knuckles on frame.
- Bang head on floor board in reaction.
- Begin cussing fit.
- Throw wrench.
- Cuss for additional 10 minutes because wrench hit Miss December (1992) in the left breast.
- Clean up. Apply Band-Aid to knuckle.
- Beer.
- Beer.
- Dump in additional 4 quarts of oil.
- Beer.
- Lower car from jack stands
- Accidentally crush one of the jack stands
- Move car back to apply more kitty litter to fresh oil spilled during step 23.
- Test drive car.
- Get pulled over; arrested for driving under the influence.
- Car gets impounded.
- Make bail. Get car from impound yard.
