Mustang suspension part out, wheels,tires,brakes,coilovers,etc
selling all the suspension from my car. i will make a photo album or upload pictures as i can take them. mostly everything is still on the car and wont be available until the end of September after NASA Nationals. We can work out a deposit or something in the meantime though. please look at the attached pdf for a more friendly version to view everything.
please let me know if you more info or need better pictures of anything. would make a deal for local people or nyspeeders. spread the word!
email me at michaelpnaab@gmail.com or shoot me a text at 716-359-2821 if you have any more questions. thats easier than logging on here to respond
Thanks,
Mike
(4) Pirelli slicks 2 heat cycles 305/660/18 450
(4) Pirelli slicks 2 heat cycles 305/680/18 450
(4) Black RPF1 wheels 18x10.5 +15 1300
(4)Black RPF1 wheels 18x10.5 +15 with Pirelli slicks 1800
(4)Silver RPF1 wheels 18x10.5 +15 1300
(2)Silver RPF1 wheels 18x9.5 +45 600
(4) Hankook C91 6 heat cycles 350
(4) Continental Slicks 4 heat cycles 400
(4) Pirelli 305 slicks 3 Heat cycles 425
Hoosier Rain Tires 1 heat cycle 400
04 IRS- full MM bushing kit The mods are as follows Maximum motorsports Delrin rear upper & lower control arm bushings,MM IRS subframe bushing,MM IRS adjustable tie-end kit,MM rear swaybar bushings & end link kit,MM urethane differential mounts,MM low profile IRS subframe bolts,Upper IRS subframe brackets,BF IRS brace,Cut factory springs. Looking to get 1,500.00 out of it picked up. I will not ship as I do not have time to mess with it. 25000 miles 1450
25mm sway bar 55
28mm sway bar 55
22mm sway bar 55
99-04 Maximum motorsports front control arms-Delrin-non offset 325
99-04 Maximum motorsports front control arms- forward offset- Delrin 325 Pending sale with 03FR500
99-04 Maximum motorsports caster/camber plates 130
Maximum motorsports rear spherical shock mounts for MM or Bilstien shocks 130
Koni (Griggs) Rear coilovers 500
Koni DA front Coilovers 600
Koni Rear DA coilovers used for 1 track day 750
Maximum motorsports HD torque arm needs new brackets from Maximum Motorsports 450
Griggs Watts link? 0
Stoptech ST-40 Calipers comes with 2 used sets of Hawk DTC-60 pads and another set 850
Built 8.8 Rear end detroit true-trac, 31 spline axles,arp wheel studs, 1350 pinion yoke- 6 track days 800
Roush rear caliper brackets would perfer to sell with rear end 100
roush alcon 13" vented rear rotors would perfer to sell with rear end 200
MOTIVE 31 spline axles would perfer to sell with rear end 150
detroit truetrac diff would perfer to sell with rear end 325
ROUSH alcon front calipers Brand new in box with pads-no brackets 700
kenny brown brake ducts 120
1.5" wheel spacers 35
Maximum motorsports Sway bar relocation kit 40 first dibs to crewwolfy
Maximum motorsports low profile control arm bolts 20
Roush Rear valances 150
Original Cobra R trunk and wing 300
1’ wheel spacers 35
1" wheel spacers 35
Maximum motorsports Cobra strut bar 120
Maximum motorsports MM3 IRS bilstein shocks brand new still in box 300
Maximum motorsports IRS coilover kit brand new still in box 275
Maximum motorsports IRS Diff brace brand new still in box 210
2" wheel spacers 55
Maximum motorsports Rear lower shock mount brand new still in box 40
howe steering column mount brand new still in box 40
98 Mustang spindles-not drilled 150
Maximum Motorsports bumpsteer kit 45 first dibs to crewwolfy, 2nd dibs taken also
JAZ 1 gallon overflow tank 45
@harvboi05
