MY MUSTANG 410 C.I. SMALL BLOCK WINDSOR FORD ENGINE
whell here goes my wife and i are expecting a baby so i could use some cash and im bored of this combo i want to go turbo next project
1969 351 block 3/4 filled .060 over
scat 3430 fordged crank and h beam rods j.e flat top pistons
sfi ford racing balancer and sfi 168 tooth flywheel
ford racing double roller chain comp cams off the shellf cam ill spec out later .620 lift
comp solid lifters comp hardend pushrods comp camd promagnum steel rockers
afr 205 heads hand ported freshened up last year with supervictor intake
canton 7 qt pan with melling oil pump
this last time i had this on the dyno it made 467 to the wheels n.a.and with the bottle was about 660 with 225 shot
in my car with a 750 nothing special carb has gone a best of 9.99 @137 on the motor and an 8.95 @151 on the bottle and that was with a footbrake and c4
the motor itself is about 6 years old but i had crank polished valve job 2 new pistons new rings bearings and gasets at april of last year it has about 25 passes on it since then it is a proven combo that should provide a decent car consistent low 10 and 9 second slips
i DO NOT NEED TO SELL THIS so please do not lowball the hell out of me id like to get 7900$
BUT NO UNREASONABLE OFFER WILL BE REFUSED
pm if interested thanks
:tup: Great seller and decent baby maker/engine builder.
Buy this motor and pwn Choda!
new lower price 6900 $$$$
