Hay my car running a lil rough and i was wondering if anybody knew of any garages or if you know someone that had a smoke machine to check for leaks in my system. I live in Sprindale right by the Pittsburgh Mills.
Thanks.
Thanks.
you telling me nobody knows someone with one of those machines or is that im not making any sense.
Seafoam?
i have a smoke machine for halloween here
ill bring my car over?
i gotta dig it out. im in upper st clair
no not that stuff, isnt that stuff used to clean out your system.
Is that what they use to check for leaks, i have never done it before or heard of anyone doing it. I just read about on the forums. They said you need a smoke maching and an air compressor.
no clue. we got both here just never have used either i think
I think your headed in the wrong direction, or your just being very nondescript when you say its running “rough”.
well its running like it has a leak lol, it will almost want to stall, but i think i fixed it this morning lol. But what do i do take the smoke/fog machine and let blow into my intake and see if i see it leaking out. but that will only help till it get to the engine. i dunno.
propane torch and a scantool
Running like it has a vacuum leak, and wanting to stall aren’t really synonymous. Do the rpm’s hang when you drive rev it? is it idling higher? If you have a major post MAF leak then perhaps it will stall, but small leaks that require smoke machines to detect normally wont.
i found the problem and yes im an idiot, the ground wire for my AFC was not that stable lol. so that was the problem.
:bigok:
and to think i found the smoke machine and oiled up the compressor
well i still want to use one, so it was not a complete waste. Im leaving for ATL tonight so i would not mind using next week, but there is a person that lives close to me and they have a maching too. But thanks i really appreciate it, but look on the bright side it will be ready to use for halloween next month.lol
i think you are afraid my mazda will eat yours
