I would like to check my boost plumbing for leaks, anyone got one that I can borrow for a few days? there’s a 6 pack in it for ya
thanks fellas
thanks fellas
it also works if you get a piece of pvc tubing the cap end and drill a hole big enough for a valve stem and put that in one of your IC pipes and fill with air. Then spray with soupy water around the joints and couplers
yeah i know, but this way will just be easier to spot the leaks, thanks for the tip though
I have a smoke machine and I did the pvc thing on my car insted. The smoke machine does not put out enough pressure to be useful.
can I borrow it anyways?
I vouch for this…borrower.
I am out in Rochester and the smoke machine belongs to my employer. So I don’t think they will be happy if I lend it to someone I don’t know in buffalo. If you can wait a month or so I would be willing to have you come out and use it here.
