need help: 15" wheels on a 91 TSI(awd) dsm people inside
15" on a 91 turbo awd is this possible? if so what offset? thanks
reason: if i can get some cheap steelies then i can get some snows someone is selling…thanks again
Hmmm I dunno. Not sure if you’ll clear the brakes. I’d have to say yes that they will fit, but I can’t say for sure. According to tirerack.com, the offset would be 40 for a 15" rim. I’m sure Gary or Don will chime in on this.
actually a friend of mine did use 15s on his 91tsi awd i think he said something about rubbing not sure what he did though because he used them all winter
Getcho 17s back with the blizzzzzzzakkkkkksss
ok i talked to my friend he used 14’s and they scraped a little bit then calipers wore down and was fine. 15’s will definetly work then
thanks
are you sure it was a turbo model? just want to double check you know
yes sir… 91 tsi awd came stock with 16s
I bought a tsi awd from a kid in rochacha it was rolling on 14" steelies before I picked it up. This may be the same kid as jkucz28 is talking about…I think his name was dustin. the 90-92.5 awds came with single piston front calipers and with smaller rotors. So you can squeeze a 14" but I suggest a 15" for less hastle.
Unless you can find-
14x5.5
195/70-14
+46mm
Stock non-turbo wheels & tires
For a chart of known good wheel combinations on dsms look here…http://www.vfaq.com/mods/macross/2Gfitment.html
thanks
i have got 2 15x6 u can borrow…unless u want to buy all 4 so i can buy to more tires for my 2 other 17 s…they have Decent all season on them
i dont need the tires ill take all 4 steelies if they fit?..how much you want? and im asumming there 5x114…thanks
justin
i had a set of 14’s from a 2g RS on my 94 eclipse which are teh same brakes…the 93-94 gsx’s are the ones that are larger, so you should be ok
pmed
