just got a new ses, and it reads p2135, tps. anyone ever heard of a code like this, i went on myspecv, and only a people have heard of it…
Did you remove the throttle body for any reason? It may just be out of calibration, or have a loose wire.
Backprobe the sensor to see if it gives the appropriate voltage closed and at WOT.
thanx, i will check today. i took it off about 1 year ago, but this just happened. dealer wants $95 just to do a test…
My old TPS had a crack and somehow that was screwing up the voltage (maybe moisture getting in). When I bought a new TPS it wasn’t set right, so it took some tweaking to get the right voltages. A multimeter is your friend.
