I need new piston rings gapped and a hone on a cylinder I replaced the piston in, where would I go around here(w seneca-ish) and price of this?
valvoline
Gorden on Commerce/N. American Dr off Union near the 400.
^ding ding ding
do it ur self?
O&L equipment on southide pkwy.
Hmm…
why haven’t you listened to me yet?
on one cylinder? you tear it down you do the whole thing.
just put sand in the oil and hook the starter up
I lol’d
try a larger hammer?
Atleast someone did
For what your asking i’d suggest a reputable shady tree mechanic. You’ll end up spending a bit less and probably get a better job done
Mikey does good work over there.
If I knew how to do it , I wouldn’t be asking.
A drill with some anal beads. I know you’ve got some hanging around.
:bigclap:
+1
i just read his “plan to hone one cyl”
fucking idiot
When I did mine I found a round piece of wood that was about the same size as the cylinder, then got some of the sicky back sand paper (forget what grit, think it was like 300), wrapped it around so it would stick. Then I took my cordless dewalt drill, after it was good and charged, drilled down in the log witha 1/4" bit till it was tight and would spin the log, then went to town on the cylinders. Pretty easy actually. :tup:
If your replacing one piston and one set of rings there’s no NEED to re-hone the other ones unless the walls are worn. And I found a whole engine kit so I am going to end up do them all since there included.
