I have a cherry picker(engine hoist), that I need to modify to be on the safe side of things for the motor going back in. When I removed the motor I noticed on the furtherest extension I was right up against the nose of my monte, and now with the paint being done I want some extra clearence from the nose to be on the safe side. Now I noticed the weight ratings going from great with the least range, to the lowest with the most range,
I want to make the slide piece longer lets say 2-3ft, will this decrease the weight rating seeing the whole piece on metal that slides in will take up all the empty space, and should put some extra welds around the base of the arm, I noticed that they only welded the outer parts not the inners,
any thoughts? :dunno:
