drvnkd
October 5, 2009, 8:22am
1
I have a 3.5" floppy master disk for some software that is a PITA.
I had a disk go bad and get replaced my the manf. but I want to make a copy of it for safe keeping so that I can avoid such delays in the future.
The entire purpose of the floppy is copy protection, so what software would be best to duplicate it?
I found a copy of “copyQM” but I have not tried it yet.
Anything that might be better for this?
Thanks.
boxxa
October 5, 2009, 8:30am
2
What software is it?
Is it a key disk or does the disk use a method of changing the address marks?
drvnkd
October 5, 2009, 8:40am
3
The disk holds the license file and transfers/removes it from one PC so you can put it on another.
Its Allen badley software.
I’m trying copyqm now…
Silly dos programs.
drvnkd
October 5, 2009, 8:53am
4
nope… apparently copyQM does not see the disc.
tpgsr
October 5, 2009, 9:35am
5
Do you want me to order you one?
I am an Allen Bradley distributor.
drvnkd
October 5, 2009, 10:00am
6
I can get free replacements when they go bad, but I would rather have an extra stashed away in my desk if I need it.
boxxa
October 5, 2009, 11:37am
7
[quote=“drvnkd,post:6,topic:74432"”]
[/quote]
I would be more worried about finding another computer with a floppy drive if that goes bad. I haven’t seen a computer with one in years. What can you put on a 1.5 MB drive now anyways?
:lol:
_Karu
October 5, 2009, 11:40am
8
you can try DOS command called “diskcopy.” it’s pretty low level, so, it might work.
drvnkd
October 5, 2009, 12:28pm
9
I had to steal… I mean borrow Fry’s usb floppy for my shenangans.
Any other software that might let me make an image of the drive?
boxxa
October 5, 2009, 12:37pm
10
Ya create a direct bit copy of the floppy. You can do it with CDs and I am sure you can do it with a floppy. This way you can keep the image on your PC and make a new floppy when needed.
drvnkd
October 5, 2009, 12:39pm
11
And how might one do that?
boxxa
October 5, 2009, 1:05pm
12
I’ve always done it in Linux and its: dd if=/dev/fd0 of=somefile.img
Would need to research how to do it in Windows.
drvnkd
October 5, 2009, 1:26pm
13
can I do it with Knoppix?
boxxa
October 5, 2009, 1:31pm
14
Ya. If you load up the linux live cd just open a terminal as root and run it.
Point the “if” to the device of your floppy drive and then point “of” to where you want the image.
Post the results becuase I am interested if it will copy it bit for bit which should catch the file system bit key changes.
I used to use WinImage to make an disk images.
drvnkd
October 6, 2009, 6:25am
16
I was going to try winimage, but I the site is blocked @ work
