I drive an 03 evo and i need a little help. Recently I saw that i had a small leak either from my t-case or my axles. I got both my o-rings from the t-case replaced and both front axle seals but something is still leaking. :bigtdown:
It looks as if its leaking from my driver side axle and the fluid thats leaking seems to be Redline MT90.
Would anyone have any idea what is can be? Also, would anyone locally be willing to look at it and possibly fix the problem?
Thanks!
You should pm carnut. Great guy
if its leaking from your axle. replace the leaking axle seal?
already have been replaced
just because it’s been replaced doesn’t mean that it seals well. installation is important for the seal to be correct for axles
idk i was just taking gary burch’s word on the installation.
I’m sure if Gary did it it’s fine. I’m sure he will get back to you shortly
i asked him when he thinks he can get me back in and he said he doesnt know lol =/
Was it overfilled as well? Not that it is the reason why its leaking but I would just be sure since it will be back in to be resealed…
this. probably wasnt put in correctly.
