I want some NGK Race Spark Plugs w/7 heat range; I don’t want used ones, so I’m looking for a place to get these. I’ve been looking for these online and can’t find them, does any of our sponsors have them or know a place to get them, also a price if you do have them. Thanks.
ka24de
Crappy Tire doesn`t have them? Parts Source can probably order them in.
Do you know the plug number? I can probably get them if I don’t already have them…
BKR7E1X-11 Most likely.
got them at part source
Yea I think the number is BKR7EIX-11 like Stiky said, I went to CT but the guy had no idea what I was talking about. Maybe I’ll try part source or one of our sponsors if that number is correct.
I have BKR7EIX, but no -11 on the end?
These are Iridium plugs, NGK’s stock number is 2667…not sure if they are what you need? $39.04/set of 4 plus shipping and taxes…
just go to napa, get copper ones there dirt cheap, switch them out more often, but yea napa…
That is a nice price, that is what i am looking for. and the 11 on the end is just how the rate the gap.
And explain to me why would I use copper ones in more detail?
copper conducts electricity better, and thus produces a stronger spark. They don’t last nearly as long as the materials they use in modern plugs today though. If you don’t mind changing your plugs often then copper wouldn’t be a bad choice
Turbo cars like copper better as well. But for a KA performance wise just stuff in Iridiums, they’ll last longer.
i got mine from nissan - i payed $20 - $25 for them
I stock a lot of copper plugs as well…the turbo guys DO prefer them, and they are CHEAP (under $13. for a set of 4). Once I figure out what plugs you guys need, I will gladly stock them also…
bkr7 go to auto select tuning wills got them in stock
Hey Ziggy, honestly pick up BKR6E1x-11 and BKR7E1X-11, they’re the most common IX plugs used in the SR20 and RB series of motors. The copper version of them is BCPR_E1X-11 (the _ is the heat range) I believe.
BKR7E - copper NGK spark plug number (V-power)
Or just go to Nissan. Their plugs are the best of all options.
BKR7E’s are the absolute most common in our motors. More so for boost. NA KA, I would just go to Nissan. The heat range is a 5 of KA’s IIRC.
canadian tire usually has those in stock try dif locations .
I keep BKR7E in stock, as the Subaru guys use them. $12.43/set of four:
https://www.rtmracing.com/xcart/product.php?productid=16504&cat=587&page=1
I wish you weren’t in Niagara falls, it’s out of the way, for me.
