bearings seam fine… i had it open last week to check them… took Chris for a ride… he said it sounded fine… Its just way to loud in my car… solid subframe bushings and stripped interior on my DD was a bad idea
I have this Same setup in my GTS-T (GT series lsd 1.5) absolutely AMAZING on the track! the .5 is a small downfall for drifting depending on your driving style, but only if you like characteristics of a welded/2way.
This setup IS bullet prof, i Run 431wheel hp, and solid twin plate clutch. my rear end just laughs when i clutch kick!
SLIDE_JUNKIE: if you are interested in keeping your setup i DO HAVE a stock GTR 2-way,
yes… correct… in order for this to work you need to use the GTR output shafts on the diff… in turn use GTR axles… which in turn would need to be used with GTR hubs… which are 5 lug
