i just bought a Pro Systems carb and my NOS activation switch wont work on it. So i will be selling it. I wanna know what you guys are running for a switch.
I have a 4150 style holley but because Pro Systems put all of the extra set screws for tuning the reg switch doesn’t bolt up like it did with my original holley 750.
this is what i have now but wont fit (mine is the same but says NOS instead of jegs)
come buy it for $15
i think this one will work, notice the set screw is the difference:
This is what I ran. It was digital WOT switch using the TPS signal, gear dependent controller based on rpm drops, and rpm window switch! Your setup will probably be way more simple, but this box was fucking bad ass.:tspry:
You can even route it to the gas pedal for WOT activation. Just make sure it’s mounted right when you do it.
This was the method for any of my super :snky: installs.
