no power
do you got power the starter
i dont know
I can stop out tonight after I change amies brakes or tommorrow:D
tommorrow going to be nice & will be able to see
oh yeah we still going to the j/y:D
yea i will go
:cool: I can check it out then so you can be ready for saturday:D :burnout:
its got to be something stupid
if you have power to hte body adn you have blown any fuses you have a bad wire going to hte starter. one of your main wires is what is touching. if it was a secondary wire it would only blow the fuse but since its a large gauge wire like 4 guage your not going to be shorting out the wire all you can do is ground that wire. what you need to do is take the wires off your solonoid. then test to see if the starter wire is grounded to the body. leave off the starter wire the hook up the rest of the wires to the solonoid. check to see if you have power to the body. also your starter could of shorted itself out and not turning over like motorlok. if it wont turn over because of motorlok then youll have all that power going straight to ground. with knowing that you may need to replace your starter but before iw ould do that i would first check what i said at first.
good luck
thanks for the help
just ground out the body of your car to something metal…
damn i got the answer
its a ford…
sorry man i had to say it
its a ford…
and this comes from a man who drives a v6 camaro that ran a 15.8:rolleyes:
i’ll run about a 17 or low 18’s when i go i bet.
15.8:hahano: :hahano:
im gonna have to go with quik on this one. check all the areas where the power wire is bare. like right at the connection of the wire to the starter. it might be hitting your block or something and grounding out. but that is odd to have power in the fenders kinda cool though
