2000 Toyota Camry, 4 cylinder, California emmisions car.
The 2nd bank (by the cat) 02 sensor (pre cat) seems to not be showing up on my friends scanner at all. Car throws a check engine light. Code is something to do with a failed emmisions component.
Called toyota, has 2 kinda of 02 sensors. An A/F one (as they call it) and a regular one.
Guy at toyota doesn’t know which one to put in. (even with vin)
Ca car, pre cat should be the A/f one as that is the one that controls the fuel mixture for the motor. The “regular” one should be there to just check that the cat is functioning properly
