I’m looking to trade for a 4 door car that good on gas - Accord, Camry, Altima, etc. Price is $4k. I would prefer $2k car and $2k cash or somewhere around there. May also be interested in old cars/truck - pre 1972.
02 Liberty - Rebuilt motor - completely new bottom end - +30 pistons, ground crank, new bearings, seals, etc - 100% rebuilt. Upper end was rebuilt as needed - new oil pump, water pump, cam chain tensioners, camshaft sensor, crank sensor, knock sensors, A/C Compressor, lifetime muffler, etc. Transmission was also serviced - both filters and 13 or so quarts of ATF+4. Everything works as it should, no lights. Fresh inspection. Driver side mirror is cracked and driver side seat it torn.
I have more money in this then it’s worth, but didn’t want to get rid of it broken. The PO overheated it and caused a rod bearing to go - had a bad knock when I bought it. One thing led to another and lots of money spent. It has about 350 miles on it since the rebuild.
[ATTACH=CONFIG]22341[/ATTACH]
[ATTACH=CONFIG]22342[/ATTACH]
