We have some parts in stock from some of our weekly sales. Give us a call at 1.877.398.8220 if you are interested in anything or pm Daryl@Rightdrive. We only have a few of each in stock so don’t wait!
Tomei Strengthened Timing Belt: $199
DESCRIPTION:
The TOMEI Strengthen Timing Belt RB20 RB25 RB26 surface is composed of a combination of Nylon and Kevlar. In addition, the cable core has been improved with high strength glass and the teeth/rubber has been improved with high saturation H-NBR. With these improvements, the TOMEI belt is 3~4 times less prone to cutting, 2~3 times stronger in resistance to heat, 3~4 times less prone to cracking and 2~3 times resistant to wearing.
FEATURES:
Although the timing belt is a common part of the engine, not all OEM and aftermarket timing belts are designed to be used on highly tuned turbo powered engines. The durability of the timing belt is greatly reduced with performance engines running at high RPM with aggressive camshafts, increased torque coming from the valve springs, extreme heat conditions from the larger turbos and more.
The TOMEI POWERED strengthened timing belt has been designed and manufactured with a Kevlar fiber (Aramid) belt surface, H-NB rubber and the glass cable core for increased tensile strength and durability. This results in a highly durable timing belt that will ensure to keep everything in check even under extreme conditions.
COMPATIBILITY NOTES:
- All RB series engines
Tomei Oil Baffle Plate - RB26DETT: $199
DESCRIPTION:
The TOMEI Oil Pan Baffle Plate RB26DETT is a very important part for your Skyline Engine because it will ensure that you will have a sufficient supply to your oil pump upon hard cornering. Without this plate, the oil in the pan will slosh to one side or another where the pick up cannot get to it which can result in oil starvation and engine failure.
FEATURES:
When the vehicle is on the corner or the time of acceleration and deceleration, oil in the oil pan will lean or jump. To prevent these to happen, baffle is assembled in the pan of stock engine. Though, in terms of sports driving, it is almost impossible to achieve its purpose because the size of the baffle is restricted to cut down the production cost. If oil leans to one side largely, air goes in to the pipe instead of oil and interrupts continuous oil lubrication. Without oil, metal surface contact directly each other, then the temperature rises explosively and causing worn out if its lasts long. On the other hand, Tomei movable baffle plate is made to achieve stable oil lubrication at any situations such as curving, acceleration, and deceleration. And it will secure the improvement of engine performance from street use to the drag racing or circuit run.
- Only for Nissan Skyline GTR.
Greddy TRUST Strengthened Timing Belt - RB26DETT RB25DET RB20DET: $168
DESCRIPTION:
This is a performance Timing Belt by TRUST/GReddy designed to with any of the RB Series engines found in the Nissan Skyline’s, Cefiro’s, Cedric’s, Gloria’s, Stagea’s and Fairlady Z’s (RB26DETT, RB25DE(T) and RB20DE(T)). The TRUST belt is composed of a combination of Nylon and Aramide which is more durable and reliable than the OEM Nissan belt.
FEATURES:
Engineered to increase heat-resistance, flexibility and durability, GReddy Extreme Timing Belts reduce the chances of cracking from heat, inconsistent timing from stretching and skipping or snapping. Improvements in materials and construction lead to a more reliable belt that will be more consistent and last longer.
Trust Greddy Oil Filter - RB26DETT VG30DETT 3SGTE 4AGE: $29.99
DESCRIPTION:
This is a standard type Trust GReddy Oil Filter with a pitch of 3/4-16UNF, diameter of 65mm and a height of 90mm. A filter with these dimensions would usually fit on a Toyota 4A-G 3S-GT type engines or Nissan RB VG type engines. Please confirm compatibility before purchasing
PRODUCT SPECS:
Brand : Trust GReddy
Product : Oil Filter
Type : Standard
Pitch : 3/4-16UNF
Diameter : 65mm
Height : 90mm
Part Num. : 13901103
- RB26DETT
- VG30DETT
- 4AGE
- 3SGTE
Project Kics Wheel Spacers (Pair) - 5x114.3: $229
FEATURES:
- Aluminum Lightweight Wheel Spacers by Project Kics, Japan.
- Wheel Spacers are sold in pairs (2 spacers).
-Does not require changing of longer studs, these spacers come with studs on itself.
- All vehicles with 5x114.3 bolt pattern and 12 x 1.25mm pitch.
Nismo Radiator Cap: $49.99
FEATURES:
The Nismo radiator cap is a heavy duty radiator cap, which operates at 18.2 lbs (1.3 kg/cm) compared to 12.6 lbs (0.9 kg/cm) non-turbo and 16.8 lbs. (1.2 kg/cm) turbo Nissan OE(Original Equipment) stock caps.
Made for vehicles that need more cooling than the stock radiator cap provides.
- Most Nissan and Infiniti vehicles after 1984.
Nismo Thermostat
DESCRIPTION:
Nismo Thermostats open at 62 Degrees Celcius while stock themostats open at 76.5 Degrees Celcius. This will allow your radiator to cool your engine before the temperature gets too high. Cooling running temperature will yield higher power and response. This will also extend engine life. This thermostat is great for turboed engines due to the amount of heat created by the turbos. This will extend your engine life and yield better reliability.
FEATURES:
· Opens at 62C degrees
· Cools down engine dramatically
· Recommended upgrade with swap
- Nissan RB motor (RB20, RB25, RB26)
Muteki SR35 Black Lug Nuts
FEATURES:
Muteki SR35 Super Tuner Lug Nuts are compact in size and shape to fit most wheels including tuner wheels with small lug holes. It is 22mm diameter x 35mm height closed end lug nut. Muteki SR35 is made of 50BV30 steel which provides high strength & durability. The set includes 20 pieces with Hex socket. Finishes include Chrome Neon (rainbow effect), Chrome Black, Chrome Red and Chrome Blue.
- Most Nissan and Subaru (anything with 12x1.25mm thread pitch)
Muteki SR35 Neo Chrome Lug Nuts
FEATURES:
