anyone stock these locally?
The Odyssey? That’s a tough one. The only thing I can imagine close is a sealed ATV/Moto battery that can have quite the CCA, which would be enough to power a Honda or similar.
What are the ratings on the Pc680?
lol dude im still using the one you sold me like 2 years ago, still works great.
Ive been using one in my truck for a couple years with no problems. Not a DD, but it performs fine. If you need it for a car, you are going to need the automotive terminals, and probably the metal jacketed version.
Specs from Odyssey
PC 680 Specs:
- 680 cranking amps for 5 seconds
- 595 cranking amps for 10 seconds
- 525 cranking amps for 20 seconds
- 17 amp hours
- Short circuit current over 1800A
- 25 minute reserve capacity with 25amp load
- Female brass terminal w/M6 SS bolt
- Length 7 1/16"
- Width 3"
- Height 6 9/16"
- Weighs less than 15 lbs
glad to hear it!
i really do need one quick like
maybe something similar?
Optima makes the smaller version of the yellow top to fit Hondas. It’s about 450 CCA, and ~15 lbs.
