plug&play traction control system for bikes
http://hellforleathermagazine.com/2008/05/bazzaz-performance-zfi-tc-offe.html
http://hellforleathermagazine.com/images/ZFiTC.jpg
Previously only available on factory race bikes or the 2008 crop of race replicas, Bazzaz Performance is bringing traction control to the masses. The Power Commander–like unit plugs into the ECU of most popular Japanese sportsbikes and requires no additional sensors or hardware to be mounted. The system measures RPMs, throttle opening and gear position, and can be adjusted to cut power when it detects that revs are rising faster than the programmed parameters. The system’s cut-in point is fully adjustable for each gear individually. For liability reasons, Bazzaz sells the system for track-use only (racers using it describe its effect on lap times as “tremendous”). The Z-Fi TC is legal in both AMA Super Sport and Super Stock racing.
