I have a 91 sr20det 180sx. and i can’t figure out what this switch is. If i push it to power a red light comes on but i notice no difference, if i push it to E-AT a green light comes on but i still notice nothing. I just leave it in the middle, but i’m curious as to what its for? could it stand for Electronic Automatic Transmission? but what does it do? any help? thanks
^^ your SR probably used to be auto. if you PM me your VIN# i can verify that in Nissan Fast.
parts that you need for an auto to manual swap are:
-5 speed transmission
-5 speed transmission crossmember
-5 speed Drive Shaft (apparently ABS and non ABS are different driveshafts)
-Flywheel
-Clutch and pressure plate
-Clutch Master Cylinder
-Clutch Slave Cylinder
-Clutch Pedal
-Brake Pedal
-Clutch hard line (unless you FEEL like fabricating hydrolic lines)
-Shift boot
-rubber shift boot and metal circle bracket (used to hold the rubber boot to the trans tunnel)
