Power FC part number
Does anyone knows what’s the part number for the Apexi Power FC for S13 Blacktop SR20DET? I heard its different from the Redtop.
Peter
what ecu do you have the 94-96 E5 ecu is (414AN015)
and theres the 96-99 J4 ecu and i dont know that one
The other one is 414AN017.
There is one Power FC for redtop, and two for blacktop depending on your ecu as already stated.
http://www.apexera.co.jp/carlife/pro_apexi/electronics/linup.html
Find the one based on your ECU year
If you get the wrong model it’s just a matter of re-wiring a few pins.
How come they have more than one part for each model?
I have the 94-96 Blacktop, so I guess I need either a 414-N004 or 414-N015 or 414-N021. What’s the difference between them anyway?
And also will a 414-N017 run on my engine?
my blactop clip ran on an redtop ecu… make of that what you will
L-Jetro - MAF Based
D-Jetro - MAP Based
As for the two L-Jetro options, you will have to check your ECU and see what it is to determine what Power FC you need.
So which ones are L-jetro and which ones are D-Jetro? Cause I can’t read Japanese.
The ones with the following in bracket is D-Jetro : (D-ジェトロ)
eg.
414-N021 180SX(D-ジェトロ )
It’s not that hard to decypher. :hsugh:
