how well do aftermarket clutch discs work on stock pressure plates? any experience? recomneded? not going to be racing
often the aftermarket discs are made to propritary specs therefore they are designed to work with their pressure plates. However many people run aftermarket pressure plates with stock discs so in that logic you should not have a problem.
Thanks Dude, you may have saved me a couple hundred
