Well i go my info back for the flow numbers for my Minin C5R heads.
lol pretty damn impressive for a stock head the exhaust is alittle week but I dont think u can ask for to much more when u can have a complete set of these heads for around 600.
I just finished flow testing a new stock L92 head. All I can says is…….WOW! What a nice part.
I’d like to publicly thank StreetnStrip for the opportunity to test this head.
The test head has casting number 5364. Here’s the tale of the tape………
4.030” test bore
Lift _.100 .150.200.250.300 _.350 _.400 _.450 _.500 _.550 .600 .650.700.750
#1 Int. 74.9 109.4 154.4 193.5 225.3 252.8 274.6 292.7 308.8 321.0 328.7 326.6 310.0 316.6
#1 Exh. 63.6 97.9 126.1 148.7 162.3 178.6 189.6 197.6 205.5 210.7 214.6 217.8 221.2 223.5
The intake was tested with a radius plate and the exhaust was tested with a 2 ½” stub pipe.
4.155” test bore
#1 Int. 73.8 108.7 153.2 192.6 225.2 253.6 277.0 296.7 313.0 326.0 335.8 326.9 327.3 317.1
#1 Exh.61.1 97.9 125.7 148.1 162.0 179.5 191.8 200.1 205.9 213.3 218.4 220.9 221.9 223.2
Exhaust port tested without pipe (4.155” bore).
#1 Exh.63.1 94.7 121.1 140.6 156.9 165.8 176.1 182.8 187.9 191.4 193.7 195.6 197.6 199.5
Valve dimensions:
Intake = 2.160” X 4.870” X .314”(8mm)
Exhaust = 1.590” X 4.920” X .314”(8mm)
Seat/throat diameters:
Intake = 1.870”
Exhaust = 1.355”
Volumes:
Intake runner = 260.6cc
Exhaust runner = 90.0cc
Chamber = 69.8cc
A few observations………. These heads have the best seat/port lineup for an as cast GM head that I’ve seen. Their casting precision is VERY good. The fit and finish of the valves are very nice as well. The intake port is large, especially the area above the short turn radius. The intake cross section starts at 3.1sq/in at the intake flange and grows to almost 3.7sq/in forward of the guide boss!
I’m a bit disappointed with the exhaust port flow. IMO it needs to be at least 25 peak cfm better. I’m sure the engineers at GM know what they’re objective was and they were satisfied with the final product but I think for hot rodding especially blown applications, the exhaust port needs to be improved. Looks like head porters will have something to do after all………
I understand that there is a company working on a 4bbl carb style intake, but I’ll leave the intake manifold subject for another thread.
Happy hot rodding.
Richard WCCH West Cost Cylinder Heads Los Angles California
:doh:
