I have searched for a while now and can’t find anything.
I need to know what the vehicle speed is at in every gear at a consistant RPM.
I am trying to calibrate my new speedometer.
If anyone has any tips please let me know!~
Search either nicoclub.com or 240sxforums.com
Both have RB sections and should have what you need.
btw, what cluster are you using and how are you calibrating it?
It is an R33 GTS-T Cluster, but I change the Speedo to a 300KPH one. I haven’t tried to calibrate it yet. I had to solder some of the connections on the back, it came with instructions that told me to jump certain points on the back of it. I figured I could just move the needle on the shaft up or down to fine tune it?
