rear quarter panel and rad gurdle
I was wondering is it possible to remove the rear quarter panels on the hatch? If it is, is it really hard do? Also if the gurdle underneath the radiator is bent, like pushed in on one side towards the back of the car does that mean i have to get the frame pulled to straighten it back out?
If I’m not mistaken, the rear quarter is removed with a angle grinder or a saws all. I haven’t taken one off, but I’m assuming that’s what needs to be done. Since the rear quarter is attached to the piece under the door (runner thing), which is attached to the body by spot welds.
Pictures of that bent gurdle might help describe your other problem.
don’t know if this is going to work, but here are some pics. If it doesn’t work can someone let me know how to attach pics to the replies.
http://www.winnipegheights.com/forums/attachment.php?attachmentid=36013
http://www.winnipegheights.com/forums/attachment.php?attachmentid=36014
http://www.winnipegheights.com/forums/attachment.php?attachmentid=36015
http://www.winnipegheights.com/forums/attachment.php?attachmentid=36016
You need to log in to the website. To post a pic just use the “Img” button under the subject of the reply. All you do is copy and paste the url of the picture, highlight it and press the “Img” button. It should end up like this:
![ “pic url” ]( “pic url” )
Yea, thats what i did and all it did was post the url.
The url has to have an actual picture though like:
www ~ .com/quarterpanel.jpeg
The url you used isn’t in that form, it needs a picture extension like jpeg, bmp or gif.
Edit:
Just right click the picture and go to properties. Then copy and paste that url into your post. If that doesn’t work then I don’t know.
