rear subframe bushings
does anyone know where i can get a set of s13 rear subframe bushings, rubber or urethane, but definatly not the solid aluminum ones.
Thanks,
Corey
pdm-racing.com
or;
I think you can order individual ones from energy susp.
or;
nissan dealer
solid aluminum FTW!!!
I got my slotted aluminum ones from bing, just get those!
f bushings. jack up your car, unbolt the rear 2 subframe bolts, 2 cups will fall out, flip them, re-install. Obtain 2 for the front from a wreckers, grind the washers off on them, install like rear were. Done, bushings bypassed, solid mounted frame.
