S13 clutch pedal and pedal bracket in S14
How well does this usually work? I have the s13 clutch pedal and pedal bracket and I’m wondering if thats the reason why my clutch is slipping…
Can anyone confirm that the s13 clutch pedal and bracket work (or don’t work) in the s14 for sure?
Thanks.
oh, and happy new year everyone :slight_smile:
Hey Bog the pedal might just need adjusting. Give me a call and I can explain the procedure or If you are down this way stop buy the shop.and I can do it for you, It takes five min.
Chris
Ah I see… maybe you can post the procedure here as well just for reference for other people.
But I’ll give you a call anyways…
Thanks.
I think I remember reading on Fresh there is a spacer you need if you use the s13 pedal on an s14.
Yeah if anyone has the write up on this it would be helpful, cuz I have the s13 pedal as well. Looking through the FSM it mentions the exact angle and the distance/gap of pedal itself but not sure what the difference would be when installing an s13 pedal in an s14. Good luck Bog!
