Crack open bleeder screw on front brakes and pump them until the front brake portion of the master cylinder is empty. Do the same for the rear.
Undo the brake lines with a 10mm pipe/line wrench and undo the two bolts that hold it to the booster. Reinstall a new one the same way you removed it and bleed the brakes. Itβs pretty straight forward.
