as the title states
all hardware and plates included.
black powerdercoat
500
obo
GT
as the title states
black powerdercoat
500
obo
GT
will the cage fit a coupe?
yes it was going to be installed in my coupe.
GT
this cage is sick, very high quality, used my many teams in japan …
pixors?
will it also fit a hatch?.. very interested
seeing as i’m pretty sure it was the one removed from my hatch the answer is yes
what type, size and thickness tubing was used to make this?
its a safety 21 or autopower cage… same shit.
its got the inspection holes and everything.
guys i need this GONE.
GT
come on this is son, its gonna take a while till u sell it
ill give u 50 bucks :bootyshake:
http://www.son240sx.ca/forum/viewtopic.php?t=19847
similar, yea?
no, its a different model…gregs has the cross beams also…
how bout i give you a punch in the adamsapple?
GT
how hard is it to mount these things? do i need any welding or do they just bolt up to the car? Can you post some pics of the cage.
you gotta pull out rear quarter plastic interior pieces and chizzle off sound deadening off the interior side of the wheel well, than you have to get it inside the car and mark all holes and drill them, after your done that you need to paint all those areas with primer first, wait to dry, than paint, wait to dry, than clear coat, wait to dry, than put some waterproof grease between plates of the cage and vehicle on ALL sides to prevent moisture getting inbetween since mounting points are where water collect. if you dont it will end up rusting through your car, than once all is done paint over all the bolts and nuts and wait to dry than clearcoat, wait to dry, than on the outside rustproof rubberized black that shit unless you want it to rust through… sorry im in a rush to eat dinner, fuck punctuation too hungry… brb
Pretty sure the cage wont fit a coupe if it’s from a hatch…
