S14 base spindle same as S14 LE spindle?
Hi,
I need to replace my spindle on my S14 but all the ones i came across are from bsae models (4bolt)…
I was wondering if I could use the spindle from the base model and just swap the hub/bearing from my car to it.
THanks.
Nima.
what did you do to your spindles to require them to be replaced??? those things are strong…arent they iron lol.
yes you can, this was once a way to get 5 lug… s14 base spindles + new 5 lug hubs = 5lug setup…now it’s easy to just get the 5 lug parts.
^^ yea, they’re the same… i had to replace one of mine which was 5 lug and i just got a 4 lug knuckle and swaped the hub and bearing assembly over.
Jon
