s14 help with wheel bearings
alright, well hope this is not to much of a noob question,
i bought my s14 with a 5 lug conversion already on it owner told me it was R33 front brakes and 300zx in the back. i believe i need to change the wheel bearing cuz my car shakes from the rear (already changed vlsd and axles look fine so im guess it that) so is the wheel bearing a s14 one or do i need to get a 300zx wheel bearing cuz of the conversion??
need to fix that shaking asap guys help me out thanks
dya check your universals in the drive shaft?
also im not sure but…
if they are pressed they are a bitch…and no matter what anyone says…PRESS THEM BACK IN FOR BEST RESULTS.
if theyre not pressed then something is not bolted down right
if u need wheel bearings ask for s14 LE or 300zx NA wheel bearings, they are both the same, but to save urself a lil extra ask for s14 LE. i dont think wheel bearings are gonna fix ur problem, bad wheel bearings dont normally cause shakes, they make a humming noise
