S14 rear brakes on S13??
Appart from the e-brake cables being different, do the S14 rear brakes bolt right up to an S13? and then can I use the S14 e-brake cables?
My rears are shot and I found a good deal on S14 rears.
Shut up you drunk.
PS
Edit. I heard you need to remove the engine and take the windshield out to do that.
Good one Cal, anyone else??
ya convert the hub to five bolt and ur mint
really,fuck!
Depends on which.
I believe the SE or base S14’s had the exact same size calipers. I’m using S14 SE fronts on my car I believe, and they are identical. The e-brake I’m not as sure about.
Ask Lith on the forums here, he will know.
they’ll bolt up and will work, but you won’t be able to use the e-brake bracket on the calipers.
