This might be a bit of a long shot.
Attempting to locate a SBC Bellhousing/Flywheel/Clutch setup.
PM me.
PM me.
Are these specific to the 4-sp? Bruce doesn’t have one he will part with.
What transmission are you trying to mate up here? Do you want a stock clutch or a built one? If your trying to mate up with a t5 transmission i have that set up and could sell it to you. Let me know.
Two piece rear main sbc and an ls1 t-56.
Ideally a 168 tooth bellhousing, 11inch flywheel and 26 spline clutch.
I am selling a Fidanza Billet Aluminum Flywheel 198581 for a 93-97 Camaro LT-1 with around 500 miles on it. That will work for your application. Click here for my thread with pictures.
85-down are 3.58" bolt pattern to the crank and neutral balance.
86-up are 3.00" bolt pattern to the crank and balanced to work with any one-piece seal L98 LT1 LT4 etc.
I meant to note mine is a two piece rear main. Not a one.
Which actually stopped me from picking up an lt1 t-56.
Didn’t want to pick up the RAMM flywheel for 400.
