Is there some type of cleaner that would be safe for an oil pressure sensor? I took it off the fitting and cleaned out the fitting, but is there something I can use for the sensor? I’m not taking any chances since there was metal throughout the entire oil system!
denatured alcohol or brake cleaner? I’d want to use something that will completely evaporate away when done.
i have some here,when u stop up for the rest,i’ll give u some!
Just out of curiosty, what’s it called?
made by CRC,lectra-motive electric parts cleaner!!!
spelled it correct cause i copied off the can!
