some please help me **TUNE** my S-afc
allright me and a friend got un-lazy and wired it up, not too bad if u have patience… and behold, it worked! amazing i no, so we go out and run, after setting up the settings to where they “should be” aka 4cyl , the other settings recommended by 2gnt, but after a few shifts, i feel that every setting the car is different, the a/f gauge keeps changing, then we pull over and see that the settings are all pre-set to starting at -14, so i set them to zero,one would assume that zero would be the right thing to start at…next thing i no the a/f richens to hell, the car is burnin extremely rich, and it stalls…after a few attempts we decide to disconnect the safc and reset the s-afc, in a life or death situation seconds later the s-afc happend to be disconnected in a rush to exit the car, im re-hooking it up tommorow but would appreciate it if someone could help set it up , the only thing i could think of is before starting the engine set all the val’s to 0, and reset the s-afc and ecu,then start it…suggestions? thanks
its easy…do u have the manual
i have the directions printed online…heres the challenge,the wiring harness for the wires it came with is about 1 foot short,my ecu is by the battery under the hood, i COULD solder ,but im kind of impatient and would rather have someone with more experience hook this up
call Hybrid…Don is good at wiring
attempting to right now thank you
We can definitely do it for you. Give us a call so we can schedule you in. 674-2772
just called there…i paid 140 for it, 100s a little more than i wanted to spend for install, im goin out now to try to find a harness to extend it,
PM sent I’ll do it today even I need the money bad.
allright maybe u can hook it up the right way, as of now i have given up temporarily
AIR FUEL constantly changes when driving…it doesnt stay the same…unless u are talking about the air fuel correction numbers but it u reset the unit it should be fine
yeah i no it changes, i just hooked up the safc and tried it,screen didnt come on but was sending horrible settings to the ecu so i disconnected it
a 100 bux is too much? Thats about 1 1/2 hours labor time. Maybe they will do it for free…:roll2:
You got to pay to play.
Devon (fuzzy) is a GREAT wiring guy … anytime i know someone that needs something hooked up, i tell them to contact him
i was talking about fuzzy when i mentioned hooking it up, and it was/is installed fine, it is the tuning part now i am stuck with
if u reset it back to default settings it wont make any corrections and it will run normal…wait to get on a dyno before u play with the settings…just decide how many channels u want to display and waht u want to display…tahts what i am doing until mike gets his new dyno
allrighty,reseting ecu works wonders,all set now…i hope
