All i seem to find is info on the flywheel toque specs…94-101 lb
But what about the specs on the Pressure Plate to the flywheel?
any specs on that?
Those are ussually not too tight. IIRC its 18-20ish ft-lbs. I don’t totally remember tho. Just snug it up with a ratched and you will be fine. Thats what I ussually do with p-plate.
Andrew.
sounds good thats actually what my buddy told me, and what he does on his Datsun
thanks
Same As KA Specs
It might be a good idea to use a bit of removable strength locktight.
tight
-deez
