sr help
i put in an sr red top into my s13. has HUD … before i put it away last fall in the mornings when it was cold the speedo wouldnt come on for a few minutes… now with the sr in it and the 20degree weather my speedo doesnt come on. may be the shitty cluster but im wondering if ne one has ne ideas? havent had it running for more then 2-3 minutes as the fans arent wired up yet.
also i installed a turbo timer i got from bing and it worked perfect when i was starting the car and testing it but when i shut the car off the key would get stuck in the ignition until the timer was done then it would unlock nad let me take the key out. i removed the ignition lock module under the l/s kick panel and now the turbo timer doesnt keep the car running but still comes on and everything reads properly. the car was automatic when i bought it. ne ideas??? thanks
