1990 Nissan 240SX Fastback
Champagne
Tint-free
Power windows
Power locks
Power mirrors
Power steering
Power antenna
Sunroof
Black rustless and wingless hatch
Black hood
Monroe rear brake pads [Brand new]
New clutch pedal mounting bracket [OEM from Nissan]
New brake master cylinder [OEM Nissan]
New (re-man’d) OEM passenger side rear caliper and brake line.
New driver-side front strut mount.
Gutted and rubberized interior [all interior panels removed, carpet removed, back seats removed, rear speakers removed, Spare tire removed, b-pillars/c-pillars removed, etc.]
Working stereo
Approx 220xxx kms on the chassis.
Comes with wheels: Black S12 meshies. 15x6 +30 with tires.
Will include the following body panels:
Black hood
Champagne hood
Champagne hatch (rusted)
Blue hood (kinda rusty)
Motor Set:
'96 Blacktop SR20DET engine & tranny [approx. 70 - 90,000kms]
Ignitor, Harness, MAF
SPEC Stage 2 clutch [High clamp pressure plate, segmented chatter-free Kevlar disc]
Machined/Resurfaced Flywheel
NGK G-Power BK6RE spark plugs
New pilot bearing [OEM from Nissan]
New “performance” clutch slave cylinder
New PCV valve
Mobil 15w50 oil
Mobil 75w90 tranny
You’ll also get the walbro 255lph hi flow pump and whatever else is attached to the car at this very moment.
There is no intercooler/piping/exhaust/downpipe/etc on it.
The only issue is that the tranny grinds from 1st to 2nd and a bit from 3rd to 4th. I’ve been told to run synchromesh or redline through it. I can get the synchromesh stuff for fairly cheap if you want it. I will not be changing the tranny fluid as the new fluid has less that 1000kms on it, you have to do this yourself.
You can either change the fluid, baby the tranny (it is definately driveable), change the tranny or rebuild it.
All you need is a tow to get this to your house.
Please do not ask about parting it out. I want to sell this complete. If it won’t sell complete (which shouldn’t really be an issue considering the price) I will part it out. But not right now.
The car is NOT driveable. The subframe is broken on two control arms. The driverside window is smashed (due to it being broken into a while back, you can search for the thread). It must be towed.
$1000
