SR20DET parts cross reference guide
S13 Redtop and Blacktop SR20DET Parts Reference Guide
Afraid your JDM engine is gonna break down and leave you hanging with no way to get parts that day? Fear not. Luckily for us, Nissan Engineers used many of the same parts on both their FWD and RWD sr20 engines.
Below is a list that I have compiled online and through various sources, includeing FAST. This list will include both crossover parts, as well as part numbers at the end. This is simply just a parts cross-reference, and not a ‘what part is better’ list.
Happy researching, and if anything IS NOT correct, please respond so I can correct it
Crossover Parts for S13 Redtop:
Exhaust Manifold Gasket: B15 Sentra SR20
T25 Turbo gaskets: '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket dose not fit on S13 T25)
O2 sensor: '87 300ZX Turbo
Ignitor chip: '95 Q45
Fuel Injectors: '95 300ZX TT (purple plugs)
Fuel Injector Seals: '95 300ZXTT kit
MAF '89-'90: SOHC 240SX
Tranny rear main seal: '93 240sx
Slave cylinder: '93 240sx
T.O. bearing: '93 240sx
Pilot bearing: '93 240sx
Clutch: 89 Nissan Maxima 240mm 9-7/16" spline 24x1
Belts: (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC
Spark Plugs: NGK BKR7ES11 or BKR6 (hoter plug)
Coil Packs: '90-'95 300ZX or '95 newer Maxima
S13 SR Oil Filter '91 Sentra SE-R
Fuel filter: '90 300zx TT
Front and Rear main seal: '91 SE-R
Temp sensor: S13 or S14 (depending on chassis not motor) KA24DE temp sensor
Thermostat: '91 Sentra SE-R
Radiator cap: '90 300zx TT (slightly more pressure for better cooling over stock cap)
Knock sensor: '95 240sx
Oil pressure sender: '95 240sx
The crankshaft main bearings and thrust washers are same as FWD SR20DE
Blacktop O2 sensors are the same as the 95 300zx twin turbo o2 sensors. They’re the fat type that phase2 has
Oil Plug: 93 240sx (Ka24de) works great. It’s the same part as the NA 300zx from the same year.
Ignitor chip: 33370-77E20 from a Suzuki sidekick awd sport
Piston Rings: FWD SR20DE
S13 SR TPS: 97 200sx
S13 Rocker Arms: B13/B14 SR20DE
For alternators you use a KA24DE alternator, bore out one of the mounting points a little bit, and swap the pulley from the SR to KA alternator
And for the part number guide:
Basically the list goes Part/Date/Part Number/Special Note
Engine:
Bare engine assembly Jan 1991 - Jan 1994 10102-50F50
Bare engine assembly Jan 1994 - Aug 1996 10102-50F52
Bare engine assembly Aug 1991 - Dec 1998 10102-50FM2
Short block engine assembly Jan 1991 - Dec 1998 10103-50FM0
Cylinder Block and Oil Pan:
Oil jet assembly Jan 1991 - Aug 1993 11560-79E00
Timing chain oil jet Jan 1991 - Dec 1998 13081-53J00
Timing chain oil jet Aug 1993 - Dec 1998 11560-1E000
Rear oil seal Jan 1991 - Dec 1998 12279-18V00, 12279-30P00, 12279-1E000, 12279-53J10, 12279-85Y00, 12279-1N510
Oil pan lower baffle Jan 1991 - Jan 1994 11113-52F00
Oil pan lower baffle Jan 1994 - Dec 1998 11113-65F00
Main bearing cap bolts Jan 1991 - Dec 1998 12293-53J00
Dipstick Jan 1991 - Dec 1998 11140-52F00
Dipstick tube Jan 1991 - Dec 1998 11150-52F00
Crankcase plate baffle Jan 1991 - Dec 1998 11038-53J00
Rear oil seal retainer Jan 1991 - Dec 1998 12297-53J00
Oil pan Jan 1991 - Dec 1998 11110-52F10
Upper oil pan Jan 1991 - Dec 1998 11110-52F01
Upper oil pan baffle Jan 1991 - Dec 1998 11113-53J02
Rear engine plate Jan 1991 - Dec 1998 30411-52F00 Plate between engine and tranny
Rear plate cover Jan 1991 - Dec 1998 30417-52F00 Plate on back of upper oil pan
Valve Cover/Cylinder Head:
Spark plug cover Jan 1991 - Dec 1998 13287-50F01
Spark plug cover bolt Jan 1991 - Dec 1998 01131-40F01
Valve cover nut Jan 1991 - Nov 1992 01217-00181
Valve cover nut Nov 1992 - Jan 1994 01217-00221
Valve cover nut Jan 1994 - Dec 1998 08918-20610
Valve cover washer Jan 1991 - Dec 1998 13268-97E00
Valve cover stud Jan 1991 - Dec 1998 13508-53J00
Valve cover red Jan 1991 - Jan 1994 13264-50F02
Valve cover black Jan 1994 - Dec 1998 13264-50F03
Valve cover gasket Jan 1991 - Dec 1998 13270-52F00
Valve cover spark gasket Jan 1991 - Dec 1998 13271-52F00
Headgasket Jan 1991 - Dec 1998 11044-50F01
Oil cap assembly Jan 1991 - Dec 1998 15255-40F01, 15255-1P101
Cylinder head assembly Jan 1991 - Dec 1998 11040-52F00
PCV Valve Jan 1991 - Dec 1998 11810-79E01
Intake valve seat Jan 1991 - Aug 1996 11098-53J60
Intake valve seat Aug 1996 - Dec 1998 11098-1E765
Exhaust valve seat Jan 1991 - Aug 1996 11099-53J60
Exhaust valve seat Aug 1996 - Dec 1998 11099-53J65
Timing chain Jan 1991 - Dec 1998 13028-53J03
Chain guide slack side Jan 1991 - Sep 1996 13091-53J01, 13091-2J200
Chain guide slack side Sep 1996 - Sep 1997 13091-2J200, 13091-2J201
Chain guide slack side Sep 1997 - Dec 1998 13091-2J201, 13091-2J202
Chain guide tension side Jan 1991 - Oct 1997 13085-53J00, 13085-1N500
Chain guide tension side Oct 1997 - Dec 1998 13085-1N500
Timing chain tensioner Jan 1991 - Dec 1998 13070-2J200, 13070-2J203
Cam sprocket (intake) Jan 1991 - Dec 1998 13024-53J01
Cam sprocket (exhaust) Jan 1991 - Dec 1998 13095-52F00
Camshaft (intake) Jan 1991 - Dec 1998 13020-1E000
Camshaft (exhaust) Jan 1991 - Dec 1998 13020-50F12
Rocker arm Jan 1991 - Dec 1998 13257-53J03
Hydraulic lash adjuster Jan 1991 - Dec 1998 13234-53J01
Rocker shim (T=2.800) Jan 1991 - Dec 1998 13229-53J00
Rocker shim (T=2.825) Jan 1991 - Dec 1998 13229-53J01
Rocker shim (T=2.850) Jan 1991 - Dec 1998 13229-53J02
Rocker shim (T=2.875) Jan 1991 - Dec 1998 13229-53J03
Rocker shim (T=2.900) Jan 1991 - Dec 1998 13229-53J04
Rocker shim (T=2.925) Jan 1991 - Dec 1998 13229-53J05
Rocker shim (T=2.950) Jan 1991 - Dec 1998 13229-53J06
Rocker shim (T=2.975) Jan 1991 - Dec 1998 13229-53J07
Rocker shim (T=3.000) Jan 1991 - Dec 1998 13229-53J08
Rocker shim (T=3.025) Jan 1991 - Dec 1998 13229-53J09
Rocker shim (T=3.050) Jan 1991 - Dec 1998 13229-53J10
Rocker shim (T=3.075) Jan 1991 - Dec 1998 13229-53J11
Rocker shim (T=3.100) Jan 1991 - Dec 1998 13229-53J12
Rocker shim (T=3.125) Jan 1991 - Dec 1998 13229-53J13
Rocker shim (T=3.150) Jan 1991 - Dec 1998 13229-53J14
Rocker shim (T=3.175) Jan 1991 - Dec 1998 13229-53J15
Rocker shim (T=3.200) Jan 1991 - Dec 1998 13229-53J16
Rocker arm guide Jan 1991 - Dec 1998 13218-53J00
Valve spring collet Jan 1991 - Dec 1998 13210-D4200
Valve spring retainer Jan 1991 - Dec 1998 13209-53J00
Valve spring Jan 1991 - Dec 1998 13203-53J00
Valve spring seat Jan 1991 - Dec 1998 13205-53J00
Intake valve oil seal Jan 1991 - Dec 1998 13207-84A00 NDK
Intake valve oil seal Jan 1991 - Dec 1998 13207-D4201 NOK
Intake valve Jan 1991 - Jan 1994 13201-53J00
Intake valve Jan 1994 - Dec 1998 13201-1E700, 13201-1E710
Exhaust valve oil seal Aug 1996 - Dec 1998 13207-53F00 NOK
Exhaust valve oil seal Jan 1991 - Dec 1998 13207-D0111 NDK
Exhaust valve Jan 1991 - Feb 1996 13202-53J01
Exhaust valve Feb 1991 - Dec 1998 13202-53J02
Front Cover:
Oil pump assembly Jan 1991 - Dec 1998 13500-50F00
Front main seal Jan 1991 - Jan 1994 13510-40F00, 13510-53J10 NDK
Front main seal Jan 1994 - Aug 1996 13510-53J00 NDK
Front main seal Aug 1996 - Dec 1998 13510-53J01 NOK
Front main seal Jan 1991 - Aug 1996 13510-53J10, 13510-53J11 NOK
Front main seal Aug 1996 - Dec 1998 13510-53J11 NDK
Oil pump gear set Jan 1991 - Dec 1998 15020-50F00, 15020-79E00
Oil pump regulator valve set Jan 1991 - Dec 1998 15132-50F00
Engine and Tranny Mount:
Engine mount right Jan 1991 - Apr 1991 11210-40F00
Engine mount right Apr 1991 - Dec 1998 11210-52F00, 11210-65F11
Engine mount left Jan 1991 - Apr 1991 11220-40F00
Engine mount left Apr 1991 - Dec 1998 11220-52F00, 11220-65F06, 11220-85F00
Tranny mount Jan 1991 - Dec 1998 11320-35F01
Tranny crossmember Jan 1991 - Dec 1998 11340-35F00
Engine - Bottom End:
Piston ring set (standard) Jan 1991 - Dec 1998 12033-53J00, 12033-53J01
Piston ring set (0.20 oversize) Jan 1991 - Dec 1998 12035-53J00
Crank Sprocket Jan 1991 - Dec 1998 13021-53J00
Crankshaft assembly Jan 1991 - Dec 1998 12200-60J10
Piston with pin (standard-1) Jan 1991 - Jul 1993 A2010-79E60
Piston with pin (standard-2) Jan 1991 - Jul 1993 A2010-79E61
Piston with pin (standard-3) Jan 1991 - Jul 1993 A2010-79E62
Piston with pin (0.20 oversize) Jan 1991 - Jul 1993 A2010-79E71
Piston with pin (standard-1) Jul 1993 - Dec 1998 A2010-54C00, A2010-75F60
Piston with pin (standard-2) Jul 1993 - Dec 1998 A2010-54C01, A2010-75F61
Piston with pin (standard-3) Jul 1993 - Dec 1998 A2010-54C02, A2010-75F62
Piston with pin (0.20 oversize) Jul 1993 - Dec 1998 A2010-54C10, A2010-75F76
Connecting rod assembly Jan 1991 - Dec 1998 12100-79E00
Con rod bearing (standard-0) Aug 1996 - Dec 1998 12111-1N500
Con rod bearing (standard-1) Aug 1996 - Dec 1998 12111-1N501
Con rod bearing (standard-2) Aug 1996 - Dec 1998 12111-1N502
Con rod bearing (standard-0) Jan 1991 - Aug 1996 12111-60J00, 12111-1N500
Con rod bearing (standard-1) Jan 1991 - Aug 1996 12111-60J01, 12111-1N501
Con rod bearing (standard-2) Jan 1991 - Aug 1996 12111-60J02, 12111-1N502
Con rod bearing (US 0.12) Aug 1996 - Dec 1998 12117-1N500
Con rod bearing (US 0.12) Jan 1991 - Aug 1996 12117-60J00
Con rod bearing (US 0.25) Aug 1996 - Dec 1998 12118-1N500
Con rod bearing (US 0.25) Jan 1991 - Aug 1996 12118-60J00, 12118-1N500
Con rod bearing (US 0.8) Aug 1996 - Dec 1998 12122-1N500
Con rod bearing (US 0.8) Jan 1991 - Aug 1996 12122-60J00
Crank bearing (standard-0) Jan 1991 - Dec 1998 12207-60J00
Crank bearing (standard-1) Jan 1991 - Dec 1998 12207-60J01
Crank bearing (standard-2) Jan 1991 - Dec 1998 12207-60J02
Crank bearing (standard-3) Jan 1991 - Dec 1998 12207-60J03
Crank bearing (standard-4) Jan 1991 - Dec 1998 12207-60J04
Crank bearing (standard-5) Jan 1991 - Dec 1998 12207-60J05
Crank bearing (standard-6) Jan 1991 - Dec 1998 12207-60J06
Crank bearing set (US 0.25) Jan 1991 - Dec 1998 12208-60J00
Thrust washer Jan 1991 - Dec 1998 12280-60J00
Crankshaft pulley Jan 1991 - Dec 1998 12303-52F00
Crankshaft pulley bolt Jan 1991 - Dec 1998 12309-29S00
Clutch:
Flywheel assembly Jan 1991 - Dec 1998 12310-79E11, 12310-79E12
Flywheel bolt Jan 1991 - Dec 1998 12315-52F00
Pilot bushing Jan 1991 - Dec 1998 32202-B9500
Intake/Exhaust Manifold:
Upper intake manifold Jan 1991 - Dec 1998 14001-52F00 Connects to head
Lower intake manifold collector Jan 1991 - Dec 1998 14010-52F00 Connects to throttle body
Throttle body gasket Jan 1991 - Mar 1993 16175-53J00
Throttle body gasket Mar 1993 - Dec 1998 16175-79S70, 16175-79S71
Intake manifold gasket to head Jan 1991 - Dec 1998 14035-53J10
Intake manifold middle gasket Jan 1991 - Dec 1998 14032-52F00
Throttle cable bracket Jan 1991 - Dec 1998 16165-52F00
Throttle cable insulator Jan 1991 - Dec 1998 18316-52F00
Throttle body Jan 1991 - Dec 1998 16118-52F00, 16118-52F05
Throttle position sensor Jan 1991 - Jun 1997 22620-53J00, 22620-53J01
Throttle position sensor Jun 1997 - Dec 1998 22620-31U01
Throttle cable pulley Jan 1991 - Dec 1998 16134-52F00
Idle air control valve Jan 1991 - Dec 1998 23781-50F05 Tousoku
Idle air control valve Jan 1991 - Dec 1998 23781-50F15 Atsugi
Idle air control valve gasket Jan 1991 - Dec 1998 23785-50F00
Exhaust manifold gasket Jan 1991 - Dec 1998 14036-53J00
Exhaust manifold Jan 1991 - Dec 1998 14004-50F00
Exhaust manifold stud Jan 1991 - Aug 1996 08267-03010
Exhaust manifold stud Aug 1996 - Jun 1997 14065-75F00
Exhaust manifold stud Jun 1997 - Dec 1998 14064-2J200
Exhaust manifold washer Jan 1991 - Dec 1998 14037-42L02
Exhaust manifold nut Jan 1991 - Dec 1998 08912-8401A
Turbocharger:
Turbocharger Jan 1991 - Dec 1998 14411-50F00
Manifold to turbo gasket Jan 1991 - Dec 1998 14415-17M00
Turbo to O2 pipe gasket Jan 1991 - Dec 1998 14445-26E00
O2 extension Jan 1991 - Dec 1998 14440-50F01
Locking washer plate Jan 1991 - Dec 1998 14495-17F00
Oil return tube Jan 1991 - Dec 1998 15197-50F00
Oil return gasket Jan 1991 - Dec 1998 15196-79E00
Lubricating System:
Oil filter bracket assembly Jan 1991 - Dec 1998 15238-52F01
Oil pickup tube/strainer Jan 1991 - Sep 1993 15050-52F00, 15050-52F01
Oil pickup tube/strainer Sep 1993 - Dec 1998 15050-65F01
Oil pickup O-ring seal Jan 1991 - Jan 1994 15059-V5001
Oil pickup O-ring seal Jan 1994 - Dec 1998 15053-1E400
Cooling:
Waterpump Jan 1991 - Dec 1998 21010-52F01
Waterpump pulley Jan 1991 - Dec 1998 21051-65F00
Clutch fan clutch Jan 1991 - Dec 1998 21082-52F00
Clutch fan fan Jan 1991 - Dec 1998 21060-52F00
Upper waterneck Jan 1991 - Aug 1996 11060-52F00, 11060-52F01
Upper waterneck Aug 1996 - Dec 1998 11060-65F00, 11060-65F01
Lower water inlet Jan 1991 - Dec 1998 13049-52F00
Thermostat Jan 1991 - Dec 1998 21200-53J00, 21200-53J10, 21200-0C810
Thermostat housing Jan 1991 - Dec 1998 11061-52F05
Engine coolant temp sensor Jan 1991 - Jan 1994 22630-V5010, 22630-51E00
Engine coolant temp sensor Jan 1994 - Aug 1996 22630-51E00, 22630-51E02
Engine coolant temp sensor Aug 1996 - Dec 1998 22630-43Y00, 22630-44B10
Engine coolant temp sensor Aug 1996 - Oct 1997 22630-44B10, 22630-44B20
Engine coolant temp sensor Oct 1997 - Dec 1998 22630-44B20
Radiator Jan 1991 - Dec 1998 21410-52F11
Resevoir tank Jan 1991 - Dec 1998 21721-35F01
Upper radiator shroud Jan 1991 - Dec 1998 21476-52F00
Lower radiator shroud Jan 1991 - Dec 1998 21477-35F00
Fuel system:
Fuel injector Jan 1991 - Dec 1998 16600-50F00, 16600-50F02, 16600-50F10, 16600-50F12
Small injector O-ring Jan 1991 - Dec 1998 16618-53J00
Large injector O-ring Jan 1991 - Dec 1998 16618-10V05
Injector insulator Jan 1991 - Dec 1998 16635-53J00
Injector rubber back cap Jan 1991 - Dec 1998 16619-53J00
Fuel rail Jan 1991 - Dec 1998 17520-52F00
Fuel pressure regulator Jan 1991 - Dec 1998 22670-52F00
Fuel pump Jan 1991 - May 1991 17042-35F00
Fuel pump May 1991 - Dec 1998 17042-73L02
Intake:
Mass air flow sensor Jan 1991 - Dec 1998 22680-52F00
Compressor inlet tube Jan 1991 - Dec 1998 16577-50F00 bolts to turbo
Compressor inlet tube gasket Jan 1991 - Dec 1998 14465-54C00
Intake rubber tube Jan 1991 - Dec 1998 16578-50F01
Ignition System:
Coilpack Jan 1991 - Dec 1998 22448-50F01
Coilpack harness Jan 1991 - Dec 1998 24079-50F00
Igniter chip (PTU) Jan 1991 - Dec 1998 22020-50F00, 22020-50F01, 22020-50F10
Knock sensor Jan 1991 - Dec 1998 22060-30P00
Camshaft position sensor (CAS) Jan 1991 - Dec 1998 23731-50F02
Electronics:
Wastegate control solenoid Jan 1991 - Dec 1998 14956-50F00
Oxygen sensor Jan 1991 - Jan 1994 22690-50F00
Oxygen sensor Jan 1994 - Dec 1998 22690-50F02
Oxygen sensor holding nut Jan 1991 - Jan 1994 20607-V5000
Oxygen sensor holding nut Jan 1994 - Dec 1998 20607-P6500
ECU Jan 1991 - Jan 1994 23710-50F00 MT
ECU Jan 1994 - Aug 1996 23710-50F05 MT
ECU Jan 1991 - Jan 1994 23710-50F10 AT
ECU Jan 1994 - Aug 1996 23710-50F15 AT
ECU Aug 1996 - May 1997 23710-60F06 MT
ECU May 1997 - Dec 1998 23710-60F07 MT
ECU Aug 1996 - May 1997 23710-60F16 AT
ECU May 1997 - Dec 1998 23710-60F17 AT
Alternator Jan 1991 - Aug 1996 23100-52F10, 23100-52F11
Alternator Aug 1996 - Dec 1998 23100-65F17
Starter Jan 1991 - Dec 1998 23300-52F01, 23300-80F00
Tachometer gauge Jan 1991 - Jan 1994 24825-52F00
Tachometer gauge Jan 1994 - Aug 1996 24825-52F20
Temperature sensor Jan 1991 - Aug 1996 25080-89903
Temperature sensor Aug 1996 - Dec 1998 25080-89907
Power Steering:
Power steering pump Jan 1991 - Dec 1998 49110-52F00 2WS
Power steering pump Jan 1991 - Dec 1998 49110-52F60 4WS Hicas
Transmission:
Clutch slave cylinder Jan 1991 - Mar 1997 30620-18V01, 30620-69F01, 30620-69F02, 30620-69F03
Clutch slave cylinder Mar 1997 - Dec 1998 30620-0H620
SR20DET transmission Jan 1991 - Aug 1996 32010-50F00, 32010-50F20, 32010-50F21, 32010-50F22
SR20DET transmission Aug 1996 - Dec 1998 32010-69F10
SR20DET front belhousing shell Jan 1991 - Apr 1995 32101-50F00
SR20DET front belhousing shell Apr 1995 - Dec 1998 32101-50F01
Speed sensor assembly Jan 1991 - Aug 1996 25010-35F00 Same as US S13
Speed sensor assembly Aug 1996 - Dec 1998 25010-71T00
Speed sensor pinion gear Jan 1991 - Aug 1996 32743-35F20
Speed sensor pinion gear Aug 1996 - Dec 1998 32743-71T20
Driveline/Suspension:
Output flange (right 5 star) Jan 1991 - Oct 1995 38220-53F00, 38220-93L00
Output flange (right 6 bolt) Oct 1995 - Dec 1998 38220-92L00
Output flange (left 5 star) Jan 1991 - Oct 1995 38220-53F01
Output flange (left 6 bolt) Oct 1995 - Dec 1998 38220-52F01
Half shaft (right 5 star) Jan 1991 - Oct 1995 39600-73L00
Half shaft (right 6 bolt) Oct 1995 - Dec 1998 39600-35F00
Half shaft (left 5 star) Jan 1991 - Oct 1995 39601-73L00
Half shaft (left 6 bolt) Oct 1995 - Dec 1998 39601-35F10
Front strut tower bar Dec 1995 - Aug 1996 E4390-50F00
Front strut tower bar Aug 1996 - Dec 1998 E4390-60F00
Nismo front strut tower bar Jan 1996 - Aug 1998 E4420-RN521
Rear swaybar Jan 1991 - Dec 1998 56230-39F03
Engine:
Front Cover:
Clutch:
Turbocharger:
Lubricating System:
Cooling:
Fuel system:
Intake:
Ignition System:
Electronics:
Power Steering:
Transmission:
Nice find and/or work Bing… this will come in handy for so many people I’m sure (Even me) now I dont gotta spend time going throu FAST, I can just check here and then confirm throu FAST where the Part # is right…
But I’m not running every single one in order to find out which are not right, lol.
True enough… and not just the other SRs from different vehicles etc… Stuff like “Main Seals” are used on a SR/CA/RB/KA etc etc
But awesome info :wink:
There’s already a few of these in our existing FAQ. Search button.
Engine:
Front Cover:
Clutch:
Turbocharger:
Lubricating System:
Cooling:
Fuel system:
Intake:
Ignition System:
Electronics:
Power Steering:
Transmission:
Engine:
Front Cover:
Clutch:
Turbocharger:
Lubricating System:
Cooling:
Fuel system:
Intake:
Ignition System:
Electronics:
Power Steering:
Transmission:
Engine:
Front Cover:
Clutch:
Turbocharger:
Lubricating System:
Cooling:
Fuel system:
Intake:
Ignition System:
Electronics:
Power Steering:
Transmission:
Engine:
Front Cover:
Clutch:
Turbocharger:
Lubricating System:
Cooling:
Fuel system:
Intake:
Ignition System:
Electronics:
Power Steering:
Transmission:
Out of ALL those #s… only 12279-18V00 is good BUT 18V00 is never stocked in CDN for some reason…
However… 12279-AD205 is the exact same Seal as 12279-18V00 and is stocked @ the T.O Warehouse
Thought I would make this post as some confirmation because I replaced both the Front & Rear Main Seals before I put my motor back in :wink:
Power Steering:
Is the above for SR20 or KA?
(based on Bings’ post i assume SR20 but i have a feeling these are for KA)
