sr20det volt problem
Ok well this is a weird one some times when I drive my car it will be fine no problems nothing everything is perfect. But recently after my HID’s went out ill be driving the car volt is at like 13-14 and when i use my brakes or use anything like signal or anything electrical my volt will drop to 10 or so and bounce back up the car will feel like its going to die but it wont and it will also do this sometimes when I’am driving volt will drop and than go back right up.
Example today coming home from work I notice same problem I press brakes volt drops and jumps back up, use signal same thing so I pull over to see if I can notice something but no everything looks fine sooo for shits I turn off the car and boom it wont start so I’am sitting there waiting and waiting trying to start it every 2 mins or so and nothing after 5 tries and than I get pissed hit my steering wheel and try starting it again and boom it works and I drive home with no problem after.I get home and try to make it happen again and nooo it works fine.
This is confusing the shit outta me please help, Thanks!
u have a short sumwhere in the wiring for the brakes light or others that causin it to ground or short out…(MAYBE your h.i.d’s) also some of your lights could be filled with water, a friend had that problem in his s13 rear lights…i think u should check if theres water first…
defiantly no water i sealed my trunk myself and their mint kouki tails so no leaks I’am leaning towards it being because of hid’s, changing them soon ill see after that…
connections or alternator…im having the same problem right now but my harness are rubbed through
