Steelies won't fit?
I got a set of winter tires w/steelies. the bolt pattern from what i was told was 4x114 so i put them on and all the holes match up but the rim doesn’t sit in properly. The hub in the middle is too big. So now i am stuck. Any suggestions on other steelies that would fit. thanks
I believe that what he’s saying is that the bolt pattern is correct, but teh hole in teh center isn’t big enough. Nissan has a very g\big center hole…
I’ll bet thet the rims you got are from a Toyota. You have two options, find someone who can put the rims on a lathe and enlarge the hole, or get Nissan rims.
-Martin.
yeah that is exactly it…these are toyota rims from an AE86. thanks for the help.
