Well myself and Andru finished up swapping all of the rear suspension out of the '87 parts car into my '84.
We hit a few…well ok, many snags along the way. If the guys on Z31.com had told us about certain parts not swapping between the rear suspension assemblies we may not have spent so much time trying to swap the brakes/diffs/axles.
In the end we ended up having to put everything from the parts car, including the brakes, cross member, diff, springs, control arms sway bars…etc. The realization about 3/4 of the way through that we could have just dropped the whole assemblies out and been done in under 2 hours was a bit of a piss off…but we moved on. Live and learn. The next time we’re pulling suspension out, it’s going to go much smoother. :drinkers:
If anyone needs tips on swapping Z31 suspension, myself and Andru are full of them now!
That they are. Despite them being about 3/4" smaller in diamater, I expect them to brake much better than the stock ones. The front brakes are the same between the two cars.
I didn’t realize z31s had two different rear tracks. I figured the antiquated suspension design was the cause of the squat problem. So which years have have the best rear suspension?
The hubs on the 87+ all are 10mm wider on each side. Swapping the suspension in helps with my camber issues as well as a 20mm wider track. It brings the tires nicely out to the edge of the fender. :E
Matt
P.S. the car only weighs 3000lb, less once I strip some of the crap out of it. :finga:
P.P.S. 3.54 stock diff ran a 13.8, new 3.7 diff is capable of 95.6% of that with all other factors being equal. 13.811 x 0.956 = 13.203s. Isn’t gearing wonderful? :E
In drag racing, you WANT a RWD car to squat. (that’s part of the reason Mustangs are so easy to launch well). The squat aspect allows you better weight transfer to the rear (driving) wheels.
In fact a lot of my problem at Bud Park is the Z32’s ANTI-squat suspension geometry. Its better overall for other situations of course, but not ideal for drag-racing. My car’s inability to squat is part of the reason for the difficulty in launching and the wheel-hop that I’ve experienced.
always check the 10th digit of the vin for year.[/quote]
They were parts cars, I wasn’t too concerned about the exact year so I just took the guy’s word for it.
It all turned out well in the end though! The car really gets down now!
