sent this turbo off to blaast performance and had the above rebuild done
never used the turbo just wnat to get rid of it save urself the time and some money i want 260$ for it
I will get the specific sizes of the turbo up in afew hours and possibly some pictures
Here is whats listed on there website for the package I ordered:
here is whats listed on there website:
Chinese Replica T3, T4 and T3/T4 turbos.
for all OBX, XSP, ZY, and other “noname” chinese-made turbocharger knock offs.
COMPLETE REMANUFACTURING to GARRETT specifications and with genuine internals.
Transforms your 129$ Ebay turbo into a Turbo of equal performance and reliability, and warrantied for 6 months just the same as a real GARRETT
Remanufacturing to new of your housings and compressor wheel. The same compressor wheel is reused, so it needs to be in reusable shape. Otherwise, we can replace it by a Garrett compressor impeller for 60-80$ depending on model.
Complete inspection as per GARRETT requirements
All new GARRETT bearings and seals.
genuine GARRETT replacement thrust system
Porting of the turbine and compressor housing scrolls that are typically very rough.
Balancing of the rotating assembly
Pressure testing
Re-assembly to GARRETT specs
6 months warranty coverage on remanufacturing workmanship and internals. Excludes impellers and shipping.
Our remanufacturing process includes the degreasing, gritblasting and polishing of all housings, brackets and impellers, including the machining flat of all flanges and the welding of turbine cracks when possible. Drilling & tapping of ONE broken stud or bolt is included. (each aditional is 10$ extra).
In case of excessive wear, specialized machining might be required in the center catridge, backplate or turbine shaft in order to install Under/over-sized bearings and seals as necessary to comply with original tolerancing requirements, which is an extra charge.
