Looking for a T5 trans out of a V6 Camaro…
Can’t use a ford spline, needs to be a CHEVY spline.
Post up whatcha got… looking for this asap.
Thanks!
Thanks!
edited
I have a nv3500 out of a 94 s10 with the 4.3. I also have the output shaft (cut the drive shaft, there is about a foot left)
Naw, I’m looking for a Chevy spline T5 with Removable Bellhousing so I can do a RWD conversion on a Quad 4.
i got a chev t5 but its v8
pretty sure you can either swap the input shaft or run a sbc/4.3L friction disc
Does it have a removable Bell Housing?
pretty sure, its been awhile since I’ve seen it dug out
Dig it out and take a look, if the bell housing is removable I should be able to use it.
