Hey guys I need a little bit of help for a starting point at where to adjust the fuel pressure down to. The car is a 99 maxima 5spd and was running a Vortech V2 s/c kit with a 3.125 pulley, walbro 255gph pump, sard fpr, vortech fmu (8:1 disk i believe) and 370cc injectors. That fuel pressure was ~40 at idle. I have had to remove the supercharger for a short time because I am doing work on another motor, and need to get this fuel pressure down lower for a relativley stock maxima aside from exhaust and intake mods.
Stock injectors are 260cc and 34psi at idle. It’s running way too rich, and I am not sure how low to go anymore considering everything has been upgraded. So what would be a good fuel pressure to set it to? Or how can i figure this out.
