I am not sure if I want to sell this or not, but I am considering selling my projector and screen. It is an Infocus X2 w/ a 60" widescreen projector screen. Quite a few people on the site have been over to my house to play it, and they can attest to how nice it is. We turned our basement into a home theator room. We just dont use it much anymore, and spend alot of the time now in the living room. Here are the specs according to Infocus:
Native Resolution: SVGA 800 x 600
Display Technology DLP® by Texas Instruments®: 0.55" SVGA DDR DMD
Input Sources Computer (M1-DA); Video (S-Video 4-pin mini DIN and Composite RCA); Audio (Stereo RCA)
Output Sources: Monitor Out (VESA); Audio (3.5mm)
Computer Compatibility SVGA, VGA, XGA, Macintosh®
Video Compatibility SDTV (NTSC, PAL, SECAM), ED/HDTV (Component, RGBHV, and DVI for these signal formats: 480p, 576p, 720p, 1080i)
Brightness 1700 max ANSI lumens (standard mode)
1100 max ANSI lumens (whisper mode)
Contrast Ratio: 2000:1 full on/full off
Number of Colors 16.7 million
Projection Lens: Zoom lens with manual focus and manual zoom adjust
Zoom Ratio: 1.2:1
Throw Ratio 1.89 to 2.27:1 (D/W), 1.51 to 1.82:1 (D/D) Minimum Projection
Distance: 1.5 m (maximum distance 9.8 m)
Aspect Ratio: 4:3 native, 16:9
Image size: (diagonal) 2.7’ to greater than 21.6’ (0.8 m to greater than 6.5 m)
Projection Methods: Front, ceiling, rear
Audio: 2.5-Watt mono
Control Projector keypad; IR remote control
Lamp: 200W SHP/4000 hours
Dimensions: 9.8"(W) x 12.9"(L) x 4.2"(H) 24.9cm x 32.7cm x 10.6cm
Weight: 6.8 lbs./3.1 kg
Power Consumption: 200 watt typical/250 watt maximum
Power Supply: 100V – 240V at 50 – 60 Hz
Operating Temperature: 5° to 40° C at sea level (0 to 10,000’); 41° – 104° F
Audible Noise:  39 dB (standard mode); 37 dB (whisper mode)
[size=2]The bulbs last around 4,000 hours, and this one is maybe around 500 or so, so it has a good 3,500 hours or so left on it. The picture is great, and the display is BRIGHT, even in light. We have played Xbox 360 on it utilizing the HD output, and its simply gorgeous. Included is the projector, the custom ceiling mount I made, power cord, computer VGA cable, screen, and paperwork.
I would like $400.00 for it, but like I said, I am in no rush to sell it, so if no one is interested, I will continue to enjoy it. If you are not one of the people that have come over to use it, feel free to stop by and check it out! I would never trust an ebay sale on something like this, so buy from me, and know you are getting a good projector and bulb!
–mark
[/size]
